cam timing???
I did a search and robothump had a lot of good info but hs pictures have all been deleted so i am stuck. The threads said that there are two marks on the flywheel right next to each other. One being tdc and one being the firing mark. The thread also says that you can see the marks through the view hole on the left side. I couldnt see shit. I pulled the dipstick and turned it over and all i saw was the line with the t next to it. I might have missed the other mark but i didnt think so.
So i assume i line the cam up with the line on the flywheel with the t on it facing the arrow just below the cyliner? or do i find this second line if any to time it? Anyone have any pictures???
Pull the large cap on the right side (8mm allen i think) and line up the two triangular arrows......much less confusing
Steve
