WC Heavy Duty Skidplate
How do I install it without squeezing the coolant breather line?
I rode it for about 30min and had a lot of coolant overflow.
The plate pinches the line but it shouldn't totally cut off circulation, so verify that first.
Are you sure that thats causing your problem???
You need to lay the hoses side by side to prevent them from getting pinched. That's what I did on mine and I have run it for many hours in 90 degree heat with no problems.
I put the two hoses side by side but this time outside the lower watter pump bolt (covered only by the engine guard of the skid plate) and it works OK; but I will have to change the hose to a longer one about 2 inches so they won't be to streched out.
