98 RM Forks - What Springs??? Eddie?
I have a set of stock 98 RM conventional forks. I want to change the springs. I went on the race tech site and the heaviest spring rate they show is 44kg/mm. Can you please advise what spring rate I would need - I weigh about 210 with gear and I'm putting them on my DRZS. I used the calculator and put my weight at 250 to compensate for the additional bike weight and it said I needed 0.50kg/mm springs and the largest available are .44.
Thanks for your input. :thumbsup: Any additional points or comments would be appreciated.
Aggressive trail - sorry that is important. And when I said please feel free to add comments, I mean: oil wieght, height, can I get by without revalving................ Thanks
valving is goo idea.the forks are from a 70lb lighter motorcycle.
.50 is a little stiff for off road work.
i would go with .48 springs and 440cc's of oil.
check with factory connection.i think they had springs still.if not cannon race craft can make them for you.
