valve check and rebuld?
I was wandering if somebody could tell me when you remove the head cover to check the valves what kind of silicone sealant do you use when putting the head cover back on? I also wanted to know when you order shimms are they just one size and how do you know when the piston is at top dead center. How much would I be looking at to have the whole top end rebuilt if I took it to the Suzuki dealer :thumbsup:
You need a service manual! You can download one on line for free. I'm sure some one has the link.
Use bel ray waterproof grease on all your o-rings and rubber gaskets. Works like a champ, no problems when taking it back off.
If you do have it rebuilt send it to WMR. WMR has some products that help your valves last longer Too. Make sure to tighten cam caps 9.8Nms only.Not 12 like the manual says.
