nedd a couple 04 rmz specs quick!!!
im putting the head back together on my 04 rmz250 and i need a couple specs. head bolt torque, cam carrier/cap torque, and most importantly valve clearances. any info as soon as someone sees this would be greatly apreciated. i know i am an idiot for not having a manual...its not here yet.
Head bolt torque = 49 Nm
Exhaust Clearance 0.17 - 0.22 mm or (0.0067 - 0.0087 in)
Intake Clearance 0.10 - 0.15 mm or (0.0039 - 0.0059 in)
Camshaft Cap Bolt torque = 9.8 Nm
Do not forget to check your timing chain tensioner for proper setting and function!!
Cyclepop,
My Suzuki shop manual shows 9.8 N-m or 87 in lbs for the camshaft cap bolts, do you have a type-o, they are only 6mm bolts.
I noticed the Intake and exhaust clearances are flipped. The exhaust is the larger clearance spec due to the extra heat.
The Head torque in 50 N-M which is 36 ft lbs.
RE
Your right, long day, fixed post :thumbsup: ---Thanks
I should have those heads back today. I have had no calls from the machinist, so maybe no news was good news???
