linkage help
i cant get the bearing out of the linkage, i have been hitting a socket the size of hte outer bearing, and ive pushed the bearing all the way to the end of the linkage( about a cm) but it wont go any farther... does it need to be pressed out?
Be sure to use a big enough socket that the race can clear the inside to come out and also you may want to lubricate and clean the link and try pushing it again
Sorry if I wasn't clear I have had the best luck on a solid floor with a large socket under the link and a slightly smaller than the race to drive it out.
