How to use a wheel bearing puller ??
pitposse_1908_39159955
Can someone give instructions on how to use this... pics of possible. i just bought one. Im tired of the ole hammer and big screwdriver approach. i have a general idea but still a bit ???
it looks like a big screw driver and a small punch with different ends to re-seat the new bearings. :thumbsup::ride:
heat your hub up with a propane torch first. heat it evenly until the grease in the bearings starts to bubble, then use the regular method of screw driver or punch. The bearings will almost fall out.
From what I can see, you do not have a blind-bore bearing puller set. A "blind-bore" set will have puller that collapses to go inside the bearing, then expand to catch the far side. Then a slide hammer to extract the bearing out. The set you have looks like a set to install bearings or to remove when you can push out from the far side. Perhaps there is something I can't see but that is my take on it from the posted picture.
