Burned-Help-Throttle cuts out
After 3x3 mod. 25, 150, 2nd clip, I have the throttle cutting out at approx. 1/2 to 3/4 throttle. I am in Indiana(close to sea level) and am running stock pipe with the billet tip. What do I need to do? Thnx-Scott
I called dynojet tech. on the matter. After trying to explain why I put a 25 pilot jet in(he couldn't understand why) he wanted me to take the air filter off and try it, then tape up the airfilter to determine if I was too rich or lean. Should I do this, or do you have an idea. Thnx-Scott
The tech thought it sounded like a needle problem
sounds like a similar problem on mine, i cured some of it with a bump up to a 152.5 mj. After some different symtoms of another sort i will go to clip position 3 (thanks for the suggestion eddie!)
you can get at it but for me its not worth the trouble. I almost always just pull the carb
Try a 147.5 main. Have you played with the fuel screw any?
I may be wrong, but doesn't the fuel screw adjust the carb just off of idle.
