Need Help, 110 Problems
I was riding today pretty hard and I herd a noise come from the head/carb area and it died. Still has compression. Not as must as before. I instaled a TB 143 big bore kit 2 weeks ago. I checked the valves and everything is good. Not sure if it stuck a ring or bottom edn bearing blew. I puled the spark plug out to check the spark and it would not give off a spark when turned over with plug out and touching the head.
Please help anyone had a ignition problems or and ways to check!!!!
