Seat Cover Question
When you put a new seat cover on, and its all kinda pulled up in the front from being pulled tight, will it eventually stretch out ?
yeah usually they do but you may have gotten the front to back too tight and should have pulled more on the side to get the wrinkles out. I usually use a heat gun to help.
Most of the time it will come out, take a couple weeks with riding.
If your feeling brave you could try using the heat gun on it now.
Thats if I understand what your saying
or use a hair dryer. it is very easy to burn a hole in a seat cover with a heatgun.
Deffinately use a heat gun or hair dryer. Makes the job much easier, if your using a heat gun, a little goes a long way, and keep it about 12 inches away from the seat, or else, like seehenry said, you'll burn a hole in the seat cover.
Ya, I set it in the sun for a bit to heat it up a little. I guess it doesnt look too bad.
