Throttle cable slack?
Mine is the same it is ok had no trouble with it. Its because its the cable that has the adjustment on it. Well i think they should of made the other one a bit longer cause when the bars are turned full to the left it pulls a little tight on it.
Nearly all pros take the second cable out so its no longer a push pull system so it has better feel. I cant see any advantage on either system.
The push pull system is to stop your throttle from sticking on, but I have never heard of that on a late model bike.
They are very easy to adjust, is all in the manual
