MCCT-Breather box/Oil return tank hose goes ?
I had to remove the black box in order to replace the ACCT with a MCCT. While doing so, I ended up pulling the hose that connects to the back of the black box way out. It appears to have come out of where it was connected but I can't figure out where that was. Does anyone know where the hose connects?
garage.php?do=viewattachment&attachmentid=24191
It just vents to open air. Stick it back down through the frame like your carb vent hoses run.
"Diddo" It just hangs free with the other hoses. Make sure it does not get pinched off.
Doesnt that one run to the airboot on an S model?
it does on mine
Yes. And also on the E model.
does not run to the air boot on a E model.
only on S/SM and 04 and newer cali E models.
It's a 2003 E. What is the airboot?
it runs straight down toward the ground from where it is now.behind the tab on the air box.
The rubber piece that goes inbetween the airbox and the carb.
Thank everyone. I must be getting old because I have been in this area of the bike before quite a bit and it seemed that, from the length, there was no where to connect it but no where that I put it to just hang "looked right." Duh, air boot=air box.
air boot=air box.
Not quite, air boot connects to the air box on one end and the carb on the other.
You're right - I was looking at the diagram for an 05 Cal spec E
Cool...well I will run it to the ground with the vent hoses then. I was at just a bit of a loss what to do with it after I did the FCR coversion.
got it, thanks much.
