04 Clutch starting to catch, but outer basket isn't grooved very much??
I have an 04 CRF450 (approximately 80 hours on it) and at the last race, the clutch started catching and lurching when I let it out evenly :ride: . I checked the outer basket and there are some grooves in it but very slight (on the order of a 1/2mm). Will this still cause it to catch and lurch the bike?
Plates look OK, but I did not check the thickness yet.
Thanks for your help :thumbsup:
yeppers that's enough. you can dress it up and get by once or twice
Not to be a dick but you running enough oil in the tranny?, My 05 went about a bugs nut low on oil and did the same thing, i drained refilled back to level and it was tits again
My 04 did that after a hard day of racing, I pretty much cooked the clutch. Even after an oil change I found the clutch to be grabby and I just replaced the fiber plates which solved my problem. My basket at the time was only lightly notched as well.
did you try taking the clutch apart and getting all the oil off the plates and putting it back in? i know they can stick together sometimes, especially if the bike has sat for an extended period w/ the same oil
I change the oil (Mobil 1 15W50) every 5 hours religously and put in at least the right amount, typically 0.05 Liter more. I pulled off the first two clutch plates and they looked good. The oil is always coming out dark and shiny looking, not sure if this is any indication.
I really have done the same thing for the past two years without a hitch and then last weekend at the races the clutch started to grap on the start. I typically rev the engine to about 1/2 - 3/4, hold the front brake and slip the clutch until the rear end loads up. Once the gate drops I let go of the brake, hammer the throttle and slip the clutch as necessary. Last weekend, as I was slipping the clutch with the front brake on, the bike would not load up without lurching as I slowly released the clutch to the point where it would normally load up.
Thanks for the help!!
My inner hub was notched worse than the basket. I had to replace that at 40 hours!! Take a look at yours also...
