Bike Back fires ALOT!
Yes, it should help, counterclockwise 1/2 turn at a time to see if it helps. A leaky exhaust can cause this too, especially around the head pipe where it attaches to the head.
has anything changed? if so look at the last thing you did. it's usually the simple things
ok
so should i put heat silocone on the header were it goes into the motor??
No, verify the stock exhaust gasket is still in place. Sometimes it's very difficult to see if it's still there. It's part number is 18291-MEB-670, it's only around $3.00.
