hot start? what is it?
ive never owned any of the new fourstrokes and i havnt riden any either so i was wondering what the hot start lever dose.
When you shut down your 4 stroke, there is residual fuel in the cylinder and the motor will be hard to start (flooded). So then you say to yourself, I'll just twist the throttle to give it some extra air to unflood it. The only problem with that is when you twist the throttle, the accelerator pump shoots a shot of fuel and it gets even more flooded. So the hot start lever is connected to the carburetor. When you pull the lever, it opens a valve that lets in air without shooting more fuel into the motor. All it does is create a vacuum leak to unflood the motor.
On two strokes you could hold the throttle open some to give it more air, because there was no accelerator pump to shoot fuel.
ahhhh. so its like a backwards choke or a manual jet. i under stand. thnx
