03 Rebuild OEM VS. Kibblewhite
Going for new top-end: Piston, Rings, Valves and was wondering if it is worth the extra $100 plus for the Kibblewhite Valves and Springs. Power wise I'm fine but if the Kibblewhites have far greater durability then it might be worth considering. Just looking for opinions and experiences.
Thanks, John Kelly :ride::thumbsup:
I put Kibblewhite springs and valves in my '02 when the intakes went to zero clearance.
They worked great, never had to shim the valves again.
Just make sure you get the valve seats touched up before you install the new valves.
I have the kibblewhite setup. It has been perfect for over 2 years and I ride over 20 hours a month.
