turn siganal problem
I replaced the turn signals on my yamaha 550 street bike
It does not make a difference if I turn on the left or the right when either is turned all signals come on and do not blink
any suggestions?
I found the problem to be the l.e.d. lights do not use enough power to trigger the system so the system was acting as if their was a blown bulb.
I was just going to ask you if you used LED lamps. You can s till u se them, but you need to add a resistor to equal the load of the incandecent bulb. Same energy consumption, but the LED's will still be more durable. Also, you can get a solid state flasher made for LED signals!
