FMF quiet core insert
I have a FMF powercore muffler on a DRZ400S
I find it too loud for street use.
Can someone tell me the dimensions of the quiet core insert, ie, length and inside diameter.
Has anyone tried this option and did it reduce the decibels by a noticable amount
Thanks
I have a FMF power core on my YZ250F. I installed the quiet core and it made a significant reduction in noise. Dont know db, but guess it would be close to 96. I think you would get similar results with the DRZ.
I'm thinking of making my own as I dont live in US
just need to know the dimensions
original powercore end pipe is around 1 3/8"diameter
I am guessing the quiet core is 3/4 to 1" inside diameter ??
Length= 5 7/8" I.D.= 1 1/4". End cap diameter wont matter core goes down inside silencer. Mine is for a YZ250F but I believe FMF only makes one quite core to fit all the Power Core 4 models.
It made it very quite but also killed the power. Although I did not rejet as I was just using for a couple rides. It probably would have ran better if I went leaner on the main jet.
Vet
Thanks a lot for that info
I found a picture of a quiet core in FMF's pdf catalogue.
It looks like a tube welded to an oval plate which attaches to the rear of the muffler with 3 socket-head screws
Is that the same as yours?.
With the picture and the dimensions you gave me I should be able to get one made here in Cambodia for a couple of bucks
Vet
Another question if you dont mind
Is the tube on the quiet core insert completely hollow or is there something inside it that helps reduce noise.
Just wondering how a 1 1/4" ID hollow tube would reduce noise
Thanks
Its totally hollow. I think the length has a lot of effect on the noise. Try it, I would think you will get noticable decrease in noise. The Power core is way loud, about 102db or so. Let me know how it works.
I think it will get you to about 96 db or around there, to me that is plenty quite. If your want like stock or around 93db, I dont think its going to happen.
