my atc70 carb problem????????
I am restoring a atc 70, im trying to keep the original carb, but the slide has froze up in it :cry: . i cant get it out, it has been sitting for a couple years and i have tryed gas, carb and brake cleaner. I dont know what to do? :ride: Anyone have any suggestions? :thumbsup:
As long as someone hasn't wedged it in there try some B-12 Chemtool or PB Blaster. Should be able to get either of them from Wal-Mart. B-12 Chemtool is the best carb cleaner I have ever used. It should be $10/can if you ask me. I think it's only $3 though. Haven't bought any in a while.
If none of the above tricks work, just soak the entire carb in a tin of deisel fuel. It works! :thumbsup:
some corrosion, I got a flat tip screw driver stuck it under it and gently worked it out, Hey i see that pic on your avator, I painted my atc70 the same way minus the my red forks. urs looks good though. :thumbsup:
