Off road goons where are you
I'm offroad only. Sometimes I think we should have a separate forum from the "roadies" :ride:
My list so far:
TT MCCT
TT Case Shields
Ready Filters
Filter Skinz
Flatland Rad Guards
13 Tooth CS Sprocket
MSR +1" Shifter (for my big ass feet)
ATV bars (for height)
Removed:
Number Plate/Headlight
Odometer
Kill Switch
Clutch Start Switch
To come:
Tonn's Racing Skidplate
Cycra Handguards
Rejet
Kick Start Kit (oh boy, more weight!)
Possibly a cooling fan or two
What a money Pit! :thumbsup:
By the way I run CR8E plugs, Honda oil, and Prestone coolant.
Im finally putting mine back together took it down to the frame sent motor to Eddie, and suspension to MX Tech. Should of had running a month ago but had my hands in to many things. Should have running next week.
New swingarm,wheel,and linkage bearings,
Renthal sprockets, DID ERT2 Chain.
MX-Tech supension- revalve, springs, teflon hard coat shock body.
BRP top triple clamp.
GPR stabilizer.
Athena 435 big bore.
Stage 2 Hot Cams intake and exhast.
RHC/Ferrea valves and RHC spring kit.
Hinson cluth basket and Moose plates and springs.
Fluidyne Radiators.
Yosh TRS exhaust.
CRF450 rear master cylinder and stainless brake line.
Removed headlight, tailight, and odometer.
I'm off road only. I think the off-roader's are the minority in this forum! :thumbsup:
I'm just getting started with mods as I just got my DRZ last month, but so far I've done the following:
Applied top triple clamp/ Pro Taper bars
TT skid plate
CFC case savers
Unabiker rad guards
Moose hand guards
Race Tech springs
Next on the to do list is 3x3, rejet, and 1 3/8" exhaust mod.
I'm 90% dirt. I don't live on a trail, so some street is required. I removed all the safety switches, armored up, got D606's, 3x3+DJ, 14/47 gearing, ceet complete seat, moose s.s. pegs, ready to :ride:
Oh yea! Red loctite- cs sprocket, primary nut, fixed water pump leak, what else do i need to fix for Suzuki? :thumbsup:
Have 3x3,exhaust,606's, Gearing, Bike Protection All Other Goodies To Make This Drz Crank And I Love The Way This Thing Do's What It Should Do From The Factory. Do Mostly 90/10 Cause I Also Have To Do Street To Get To Trails.
Harry, why do you keep the rear light ?
Neil.
:thumbsup::cry::ride:
So he can find the bike when he runs it off the trails :ride:
I'm 95% offroad. I only use the bike on the street to connect trail networks.
Mods are...
-Kenda K760 rear tire.
-Pirelli MT21 front tire.
-White Bros engine skid.
-14/47 gearing.
-Alloy bars.
-EMGO hand guards.
-Fan & Thermostat removed.
-E model t-stat gasket.
-Passenger pegs removed.
-Sprocket cover removed.
-Smaller tail light.
-CFC case guards.
How's this for offroad only:
garage.php?do=viewattachment&attachmentid=21756
You should have some boots on those forks.
Rocks will damage them and dirt & mud will wear the seals out early.
Been there and done it.
Put the DRZ in the dirt.....who the heck does that? :thumbsup:
Tonns skid plate
CFC Case savers
Bark Busters
Eliminate Clutch Switch
3x3-n-rejet
Neil.
Harry's answer.
I want guys behind me to know when I'm braking?
__________________
I'm not sure who to believe here, should we have a vote on it :ride:
No, it's alright Harry, I believe you.
Neil. :thumbsup::cry::ride:
You know what made my bike fast?
Putting my Old Man on there. That crazy old fart (if 48 is old) can ride!
