Replacing Inside Spokes
I have a couple of inside spokes that are broken. I have heard that I have to completely remove the rim to replace them. Is this correct? If not, what is the trick? It seems the other spokes are in the way when I try to install the new ones, and if I remove the ones that are in the way, I cannot get them back in place.
Thanks,
Steve
You heard correctly. The there is no other way to replace inside spokes without taking the rim off.
i replaced a broken inside spoke on the rear wheel last nite on my xr100. i only had to remove one spoke to be able to feed it thru.
