rcm carb problem
i have a rcm pit bike and the gas keeps leeking out of the overflow line. so i took it apart and the float was struck so got the float moving again. i put it back together it was good and now it is driping again. i was wounding it any one eles has had this problem and how did you fix it.
you need to adjust the float bend the little tab that pushes the plunger up
He just told you.
A lot of floats seem to stick on these smaller carbs. Smack the float bowl with a screwdriver handle. Problem solved.
