Help Klr 650
When coasting in gear my '03 KLR 650 gives out a wicked Clack, clackity, poptiypop-pop-pop, SNAP.
What's going on here? :thumbsup:
First thing I'd check is for excessive drive chain slop. Hope it's nothing more serious than that. good luck.
Backfiring? or mechanical noise?
Backfiring and popping on decelleration is common , the bikes are sold running really lean from the factory. Remove the plug at the bottom of the carb that covers the mixture adjust, close it totally, then turn it out 2 1/2 turns.
Should stop the popping.
Other areas to check, spark plug, air filter and exhaust leaks.
