Xt 500 Needs Help
I heard that u could lace up a new motorcross tire to an xt500 hub. But what motorcross rim should. and what spoke kit should i use. I NEED HELP i have just gotten my modded xt running right and i wanna have a semi motard PLEASE HELP
i know this is a real late post so i hope you see it .what you're probably going to have to do is order the rim size you want from someone like excel or sun metal as you probably won't find a rim off of another bike that will have the spoke hole drilled at the proper angles.as far as a spoke kit it's going to be a custom fit and the only place i can think of that will make them is buchanan's as far as far as that goes you could send your hub to them and have them build it unless there is somebody locally you know that builds wheeles.hope this gives some ideas
