426 w/ LOTS of popping on decel.
When my bike is warm, after having been ridden for a while, it pops quite a bit when I let off the throttle on decel. Should I check for exhaust leaks, fuel mixture, or jetting? Also, this is not normal popping, it does it a lot, and it is nonstop off throttle.
fuel screw on the bottom of your carb, there's probably nothing wrong with your jets. It's called a pilot screw and if you turn it out a little bit it should be fine. My yz250f did the exact same thing, its an easy fix.
Luckily for me, it ended up being the head pipe on the exhaust being way loose. I've only had the bike for a few weeks, and I guess the previous owner did not have any Lock-tite on the bolts, so I put some on, and tightened them up, no more popping. It was able to be moved a few inches up and down.
Glad you caught that. Most will say it is good practice to check the important nuts and bolts before a ride. Now you know why.
Doug
