is it time?
you should pull the head cover off and check the clearances with a feeler gauge. if you own a service manual find out if they have proper clearances. if they do not then use the chart in the service manual to figure out what size shims you need and then replace the old shims. BE CAREFUL TO NOT DROP THE TIMING CHAIN, CLIPS, OR SHIMS INTO THE MOTOR!!! this proccess only takes roughly an hour.
Is this thing brand new??
If it's new, I doubt seriously if it needs adjusting.
If it's used, you need to find out where you're at to determine if it needs shimming.
