450 rod bearing
tore down my 450x today, intakes are going tight every ride....
new piston to, just wondering dose the 450 have a rod bearing???
i cant tell.... : ... it looks worn, but the wrist pin seems tight... :thumbsup:
Yes, it has needle bearings with a cage.
My cage came apart, and the shavings collected on the pick up coil, and killed the spark on the face of a jump, = broken femur. Last time the head was off, it showed no signs of excessive slack or side play. I could here no abnormal noise from the engine either.
really..... i pulled mine apart today and there were NO needles or a cage the wrist pin fit tight, if ther was a needle bearing in there the
wrist pin would not fit..... and they didnt come out when i took it apart ..
i change my oil after every ride and no metal chunks on my drain plug..... :thumbsup:
