Cometic Questions..
Hi guys, I have a few questions on the cometic top end kit.....
1. Is the base gasket the high compression one for the 'e' model?
2. Does the kit come with a gasket for the cam chain tensioner?
3. If the answer to question 2 is no, does the MCCT contain the gasket?
Cheers
Peter
Cheers
Peter
1. yes
2.no
3.MCCT from TT comes with an O-ring seal . not sure about the others
That was quick, thanks!
I need the gasket for the tensioner, as the old one came off in 2 bits. Thanks for your assistance,
Peter
If you are replace the acct with an mcct then not sure why you'd need a new gasket?
The cometic set includes the three ply head gasket and the single ply base gasket.
