stator plate replacement
Will someone explain how to remove/replace a stator plate on a zongshen 125? thanks im a little lost
What are you replacing it with? Kitago, Takagawa?
You need a 2-3 arm puller to remove the fly wheel and a plastic mallet to hit the old unit lightly to break it free, it just pops off. The plate should just have 2 screws that slides off with a slight effort.
I just did a Kitago on one of my CRII 125s it was very easy, new wires and electrics replace the old wiring. I did use the original kill switch though. Will finish it up tonight with the rest of the mods. :thumbsup:
thanks..i am borrowing a puller from a tech here at work and will give it a try tonight
have some patience with pulling it off mine took a bit of fussing...........
all of a sudden it popped right off with just the right light smack with the plastic hammer.
I did not have time to fiinish the welding on my pipe so i'm not yet running......
good luck :thumbsup:
