Raising Forks in Clamps
The bars and front end can flex slightly so I might move them down a bit just to keep things from hitting. You have rubber mounted bars, so if you have the bars resting on the forks it could create some vibration and/or mar up your bars and forks.
Raising them 5,to 7 mm is all you need, any more them that, you should go for new clamps, with 22,or20 mm offset.
