quick exhaust question
ok I'm about to install my new pro circuit Ti-4 slip-on but have a question, on the stock exhaust there is a little seal or spacer in it. it is silver. do i put it in the PC? it is where the header and the silencer go together. the inside diameter(sp) are the same with it in the stcok one and with out on the stock one.
Thanks in advance :thumbsup:
no you don't have to put the little seal/spacer w/e in the pc pipe
nah, it is a slip fit. You can put a bead of high temp silicone around, but I have found no need for it.
one more question, the clamp on the outside on the stock pipe it to big for the PC one. do i need it? i just tightened it to a thicker part of the pipe behind the kick starter.
