skid plate question
i have a works connection skid plate, and my question is about the clamps. i am wondering i have three of the clamps on with no problem but it seems like i have to unmount the engine mounts to put on the clamp on the brake side. the one in the back . any help?
I've put three of these on three different motorcycles without having to unbolt anything. Did you put the holding bracket between the frame and motor prior to screwing it into the skid plate? Worse case, I had to trim a little off of the tip of the bracket to get it to slide through on my bike that has a CR500 motor installed in a CRF aluminum frame.
I just installed a works connection skid plate on my CR250 and it took a little patience and fidgeting around to get the clamps in right. Start with the flat one first and then put in the ones with the hooks. Worked for me.
