02-04
Will everything apart from the muffler fit if I change an 02 frame for a 04 ?
Was there any improvements between these models?
Yeah everything pretty much bolts up,you probably need the black box mount from the 04 ,and you have to toss the spacer on the bottom motor mount and I would get the later motor mount plates and bolts to suit they are the same in 03/04 and are thicker and reduce vibration compared to the 02.If you use your 02 sub frame you can use your 02 muffler.I don't think you gain anything in handling as the geometry is the same although the front frame down tube in slightly thicker.If you want it to turn better use the linkage from the 03/04 and the later rear shock spring or the right spring to suit your weight.Hope this helps.cheers
