quick valve adjustment question
I just checked the clearances and they are
Exhaust: left .33 right .28
Intake: left .18 right .20
Should I reshim the .33 to get it down in the .2-.3 spec? What could have caused this to loosen that much?
Two things are common to cause a loose spec.. One bent valve not seating, worn, ruined cam journals. Neither of which happens as a single failure..so if all else is well...... I'd say you measured wrong or someone else set the clearances too loose.
Ya, I'd up the clearance to .3 or less.
which is what I want though correct, the exhuast that is at .33mm has a 300 shim in it. I was going to go to a 305 to get it to .28, so I will have .28 .28 exhaust and .18 .20 intake
Correct on the shim size ?
As far as that being what you want? I'm not you but I'd be willing to bet that that is what you want....me on the other hand tend to run mine spec'd differently. But I'm also running different cams.
