What are you guys running for sag?
hey all,i was wondering what you guys were running for your sag and how it was working for you.I weigh 155 lbs am a midpack b rider and have a 25 mm static sag and 95 mm race sag.The suspension was done by proaction if that matters.Any insight appreciated.
20-30mm static and 100-110 race. Getting the proper spring for your weight is the most important. Each rider and tuner may vary due to conditions..
where was ur suspension done? y are you asking, is it kicking wierd or bouncing or something? sliding in corners?
pro-action is where my suspension was done.It handles awesome in the corners but the rear end can be sketchy at times and it is a little unpredictable in some whoops where as in others its amazing.
I run a little more sag personally and i also run my front harder compared to my rear. I like my back end to kinda squish in the corners. I just set my sag at 4". i meant where is the pro- action that u got it done? jw
its at two wheel motorsports in guelph,i ride for them.i can get a diff spring if i have to but am not so sure i need it.i think ill try it at 100 mm and see how that works.thnx.
