Mikuni idle problems
I have a Mikuni flat slide carb with accelerator pump on a 2003 DZR400s with FMF system
The bike runs a bit rough at idle and hesitates when I crack open the throttle from idle
Idle sometimes hangs on decel
Fuel mixture screw at 2 3/4 turns out seems the best compromise
Over 3 turns out cures the idle hang but bike runs rougher at idle, hesitates more when revved up
I plan to strip and inspect the carby, check jet sizes .
Other than pilot jet size, what else should I be looking at for the cause of the problem
Can a worn slide cause idle problems ?
Eddie
I dismantled and inspected the carb today.
Only thing I could find that may be causing the hanging idle problem is a worn throttle valve.
When it's closed I can move it back and forth around 1/16".
So thats the amount of wear in the slide .
Can you tell me if this amount of movement is
excessive ?
With the engine running, if I open the throttle just of idle, i can here the throttle valve slapping backwards and forward in its slides !! Sound goes away after a few seconds
The other possible causes you suggested checked out OK
Also noticed that my carb has a column of rollers down each side that the throttle valve slides over
I couldn't find a diagram online that show those rollers for a Mikuni 36mm with pumper ??
Eddie
Since my carb is a Mikuni flat slide with pumper I assume I have a pilot air screw rather then a fuel mixture screw.
My adjustment screw is located bottom center of the carb body towards the motor.
So screwing in makes mixture richer ?
and out is leaner ?
As I previously mentioned, the bike idles best at 2 3/4 turns out, and idle hanging gets worse at less than 2 1/2 turns out.
Question: should I be looking at a bigger/smaller pilot jet to cure idle hanging
Note: I run a FMF powercore exhaust. Airbox is stock
Thanks
From your description of the screws location, I'm going to say it's a pilot "fuel" screw, not an air screw. The positions of the screw where it idles best and where it hangs is also indicative of it being a fuel screw. So, out would be richer and in would be leaner.
Thanks Eddie, Trailryder
I think your right, it is a fuel screw on a 36 mm mikuni pumper
So where I'm at now is the bike idles best at 2 to 2 1/2 turns out on the fuel screw but idle hanging is bad at this point.
3 turns out the bike idles (a bit rough though) and the idle hang is reduced slightly.
Is a bigger pilot jet going to fix this problem ?
Thanks
