clutch light
Is it normal to have the HighBeam turn on when I pull the clutch all the way in? :thumbsup: So every time I shift gears or stop at a stop sign the HighBeam flashes for as long as I hold the clutch lever to the bars.
Have a look at yout switch block,there is a button at the top that is to flash your headlight to pass,either raise your clutch or lower yout switch block.
