fork oil help fast please
i took apart my 2000 rm 125 forks and out them back together with 360ml of 5 wieth oil, i took it out and when the front end comes up its smacks then and it seems to be very springy, is this due to the oil ? and help would be greatly apriciated, do i need a thicker oil?>
How did it go about connecting the damper rod to the fork cap? Are you sure it is well threaded with the lock nut to keep the damper rod attached to the fork cap?
did you bleed them? :thumbsup: and If they are not the twin chambers then they go by oil height not a set amount. :ride:
