Oil Screen Cleaning
I have an 06 DRZ400S with 1100 miles on it and wanted to check the screen, change the filter, and try the Mobile 1 4 stroke synthetic. You will need 12mm, 14mm, and 24mm sockets and 5 crush washers. I made the mistake of assuming my local Suzuki shop would stock washers and I was wrong, get the parts before you start.
http://www.oem.thumpertalk.com/2004DRZ400Soilhose.aspx
09168-12002 x 1
09168-14015 x 2
09168-18007 x 1
09168-10002 x 1
The screen is large and mine had almost nothing on it, flushed tank with some oil, cleaned the inside of the tank as best I could, and put it back together. Not sure it was worth the effort, but it needed to be checked.
Exactly right but all those crush washers don't need to be changed very often. In fact, after 6 years I have not changed any. Also, you my want to add the filter "O" rings to your list to have on hand.
