Rg3 really stop arm pump
It does help, I wouldn't say that it stops it. I have just the top, got it on ebay for $185, hardly used.
Some other things to try,
1 change bar position
2 change lever postions
3 change bar bends
4 stop holding on so tight
5 work out
6 stop holding on so tight
7 RG3 clamp
8 steering damper
9 you really need to work out more if you are at 9 and non of the above has worked. LOL jk
If you breath deeper/better and loosen your grip it may cure your arm pump, works for me!
I agree with the comments above.
Relax and quite hanging on so tight. (I know, harder to do that to say...)
Anymore, it's an automatic upgrade when I get a bike - RG3 uppers are put on before I ever start the bike.
Running a set of Pro-tapers will also help, as they dampen vibration quite well - but if you really want to get a smooth, about as vibration free setup as possible, run the RG3's and Fasst Flexx Bars. I have this setup on my 450X and it's fantastic. - and once I bend the Fatbars on my 450R, I'll replace them with Fasst Flexx bars.
No, you don't have to run the lower clamp to get results.
Sorry for the confussion. I dont get arm pump. I am in good shape. I was just wondering if it really works and it sounds like it does.
Does RG3 top triple clamp really stop arm pump?
Lol! How easily we are confused... :thumbsup:
