Throttle Drum Question
I am in the process of putting the carburetor back on the bike and hooking up the throttle cables. Should there be any play in the 2 cables or no play? I'm having a hard time with the lock nut and adjusters. Are there any tricks to get this right?
loosen the nut all the way to fit the cables on, there should be a little play, but its ok if there isnt..... once you have it all the way loose put the cable in place and tighten until slack is gone
