"S" Carb Float Level
What is the proper method to measure the float level in a "S" carb? Did some searching but couldn't seem to find an answer. I wanted to check as I have a bit of the off-idle bog with the 3x3 / Dynojet kit / "burned" suggested jetting and fuel screw setting method.
Thanks in advance.
13mm + or - 1mm. It is measured at a bit of an angle. I turned mine horizontal with the float just barely seated to get a good measurement.
Thanks, but my question was intended to understand the method of checking it.
Thanks again.
