Carb problem??
it has been 1 mth my bike bog despite a top overhaul of my jammed valve. I dunno watz the problem but i suspected my carb. then today, i juz realise petrol leaking from my carb.
so to sum it all, my bike bog/cough and my carb leaks. what's the problem?
If it's leaking out an overflow line, the needle valve may be bad or stuck open, or the float level settings are wrong. All of those will let the carb overflow.
Who overhauled the jammed valve? Are you sure they got the cam and cam sprocket back on and timed properly?
itz not from d overflow line. i dunno how to describe coz i dunno where exactly itz leaking from. itz like my whole carb is wet til it drips.
a reconized local mech did the overhaul. anw, before he overhauled my top block, my carb seems to have a little leak. only today i found out itz worst.
2ndly, whats with my bike bogging? carb related too?
I'd check the simple things first. Make sure the fuel line coming from the tank to the carb is in good shape, not cracked and leaking. Take the carb out and make sure the float bowl oring is there and in good shape. While you have the bowl off, check/set the float levels. Check the tip of the needle valve for wear. Use compressed air or blow thru a straw and blow out all the little fuel passages of the carb.
What year and model bike is this?
There my carb goes again... dis morning itz leaking quite alot. BUT to my surprise and confusion, itz only leaks when the bike is park overnite. ydae after werk b4 i rode home i checked my carb, itz leaks only a little and when im riding, itz not leaking.
n btw, itz a 97' xr400
yup.. i leave it on. but before wasnt a problem.. anw im gg to get it checked ltr.. tanx alot
It's the float valve...Fuel is continuing to flow into the bowl while it sits, and then when the bike is running it burns some of it down, so it no longer leaks, but bogs instead. It is an easy fix. Just bend the tab on the float, until it turns off at the right spot. I'm not sure what the spec is...
