pros and cons
Only con I have on the '06 is that it gets heavy at the end of a Moto. Other than that these bikes rock.
Pros:
Excellent Ergos
Smooth strong power
Excellent frame (flex and geometry)
Amazingly good stock suspension
Pro Taper bars
Excel wheels
Great brakes
Cons:
Bottom end is a little soft but it helps keep the bike hooked up
Crappy stock front tire
Carb access can be a hassle
Pros:
Excellent Ergos
Smooth strong power
Pro Taper bars
Excel wheels
Great brakes
Cons:
Pretty much sum's it up, although carbs on Honda's are even harder to get to I hear?
Not true. The top motor mounts on the Yamaha make it a pain to mess with the needle. The Hondas don't have that problem. Plus you can turn the Honda carb more than you can on the Yamaha by just loosening the boot clamps.
I would have to agree with RedBeard.
BTW - what front tire do you reccomend?
Haven't experimented with the Yamaha but I just got a Maxxis SI that I need to try. I normally run Bridgestone M401A's. They work well pretty much everywhere, from mud to silt to loam, blue groove, whatever.
I bought my 06 used and it came with an extra dunlop 756... is that better than the stock and what is the stock tire?
How do the bridgies hold up? My 756 is gone after a couple rides on a hard pack track. I ride all sort os tracks though...sand...loam....mud....concrete (aka hardpack)....blue groove.....
They hold up pretty well. The 402A series which is the 120/80-19 has harder rubber compound on the center lugs for better wear while the outer lugs are softer for better lean angle traction.
I like the 401 I'm using on the front of the '03. Better traction, and a wider transition between stuck and unstuck.
We've got a D952 on the front of the '06 right now, and it's worked great in everything we've encountered. We haven't played in the mud yet, though.
And I haven't had the 952 on the '03, or the 401 on the '06, so it's a little hard to compare.
I seemed to get the whole tire sizing confused....how does a 110/90 compare to the 120/80 that you run? That 402A sounds good, but do the side knobs hold up....I have torn a lot of knobs off my michelin's in the past (M12).
The lugs hold up good. The 120/80 is pretty much the same height as a 110/90 but it's a bit wider.
