shorter clutch lever, and another question
Does anybody know where I can get a shorter clutch lever? I don't really need the length of the stock one.
Also, is there a metal replacement nut for the plastic nut where the hot start cable goes into the top of the carb? I have been removing mine a bunch of times as I am fine tuning my jetting and the threads are starting to go. Why the heck is it plastic to begin with???!!!
Thanks in advance!
Danny
ASV makes a shorter lever and perch assembly
Leave the hotstart nut plastic. If you use a metal one and tighten it down to much, you will break the carb body off around the hotstart. It is much cheaper to replace and fix the plastic nut then a carb body.
Moose also has a shorty clutch lever. It is about $10 bucks.
quite a few brands offer them...go and ask for a shorty style lever from your dealer...
