does anyone use a REKLUSE in motard riding?
my bike has a rekluse for woods racing in it...
if i go the "throw some slicks on there" route...will the rekluse be a problem?
Few guys over this side of the pond using them to great effect, never tried myself but my mate swears by them and he aint slow........
Cheaper than a slipper clutch, but almost as effective. Your bike will be faster with it on than off.
One of our faster riders has one in his bike. We swapped off for a while and I sort of liked it. Mostly I liked it but I would need to get used to the left lever being the rear brake instead of the clutch. At least that's how he set up his bike.
The clutch itself worked fine and he's doing really well with it so it'll stand the pounding fer sure.
Our german distributor has a guy that makes a thingy for our left-hand brake kit that pulls in the clutch when you pull in the left-hand rear brake (it's fully adjustable so you can adjust how much clutch slip you get with your rear braking). I've tried it on a dirt bike in the dirt and there really isn't any advantage to it in the dirt. The germans swear by it for supermotard and are apparently selling a lot of them. We've never really gone after the supermotard market here because there's no supermotard scene here in Boise and none of us have a supermotard bike. I intend to own something and come up with a place to practice by next spring.
If anyone out there is using the z-Start for supermotard and wants to try this setup out, I'll make you a sweet deal on the left-hand brake kit with this setup (and make it fully refundable if it doesn't work out for you). I'm looking for some feedback. I only have one of them.
I guy from the Seattle area won a northwest series championship using the z-Start a couple years back and then retired from racing. I know there are a some guys racing in some of the European circuits as well with the z-Start.
If you're interested email to al at rekluse dot com.
One advantage to the Rekluse is it makes it easier to get great starts.
Local guy Bob Reinen has one on his 450 KTM and is almost always 1st
or 2nd into the first turn. If you can start well half of the battle is already won.
You can quiz Bob about it at www.cyclebuy.com or at www.supermotojunkie.com in the Washington forum.
Youngwerth. Jump on the washington racing forum on supermotojunkie. I think our SMUSA KTM test bikes use a Rekluse (2 of the 3 testers in fact) Look for cyclebuy, motarded, markr, norm908, or ronwest99.
I am sure you can find someone to test...I will send them to this thread.
I have a Rekluse in my SM450R husky that I ride on the street. I installed the Rekluse just for something different. It actually works pretty good and I get the holeshot with 2nd gear starts at every stoplight. I can also usually carry a gear higher than usual with the autoclutch, since it will slip a bit till the revs pick up. Makes a fun bike even more fun!
Al,
We have a work party/practice day at McMinnville coming up on August 13th. It would be a perfect day to do some testing. We could put it on my 2005 450 SMR.
I will email you about it.
Bob R
CycleBuy.com
It seems like the few people that have them like them "according to their buddy". Here's a couple questions:
1 does it heat up the motor oil any more
2 if properly addjusted does it where the clutch plates any faster (it must)
3 are there any disadvantages other than cost
4 does it make it any harder to learn how to "back it in" or any thing else with out a clutch
Thanks!!
I have one on my WR450 which I use for dual sport and trail riding.
I have not motard raced it. With it adjusted properly it does not slip the
clutch any more than you would by operating the lever manually.
It may actually slip it a bit less since it is consistantly controled.
If you are running the motor hard in too high a gear you might get
more heat and wear but again not more than you would if you were
feathering the clutch by hand in too tall a gear.
The Rekluse retains the clutch lever which works kind of like an override -
pull in the lever and it disengages like a normal clutch. This is a nice feature
but can get you in trouble if you aren't paying attention. If you pull in the lever
to make a couple of down shifts and allow the RPMs to drop too low when you
let the lever back out it will not re-engage but will freewheel. All you have to
do to re-engage it is blip the throttle to pick up the revs but it can be a little
hairy when you aren't expecting it like catching a false neutral in the middle of
a corner. When I an riding the twisty pavement at a fast pace I have to
keep reminding myself not to pull in the lever.
This can also be a problem trail riding on a steep downhill. When the revs drop
near idle you no longer have any compression braking - it will just freewheel.
Does the override take as much effort to pull as your clutch lever does now? Just curious because I've seen some people use the hot-start lever for the override and I can tell you there is no way I'd be able to do that with my normal clutch effort.
Grant
The effort varies with engine rpm. At idle you could easily use the hot start lever.
With the engine revving in the mid-range it would be a pretty tough pull.
I use a Rekluse for Trail and Supermoto riding, mine has been fitted for the last 18months, with no effect on clutch life so far...oil changes are the same intervals as normal !
My set up is the full monty with not only the back brake up on the left bar, the foot brake is retained as well, and I have a 2 finger override for the clutch as well... (this is because we use my bike to Demo the product as I am a UK dealer for them... :thumbsup: )
the effort to pull this is very little, I can pull the clutch in at ANY RPM to pop the front up, pull wheelies, whatever.....
Any pictures? How 'bout a pic of the dual levers? i take it that dual levers is the way you have it set up. This sounds like a primo set-up to me.
Anybody have any ideas how to make it work on my KTM, which has hydraulic clutch??
??Anybody know of a smaller hydraulic level configuration i could use as the two finger "override" on clutch, and convert the current level over to rear brake??
Anybody have a better idea?
the dual system really only works with Cable clutches, you can fit an override to the KTM BUT not with the rear brake up there as well... heres some inages of the set up on my bike....
Thanks for posting pics GUY. That is one sweet set-up.
Great: One perch, two levers - With fine control and modulation of rear-wheel braking.
i plan on finding a solution like yours, for dual hydraulic levers.
Wish me luck.
Al,
Bob R
CycleBuy.com
Welcome to the site Bob :ride:
I will be coming down with the Berg, as well the Club's 450 SMR Demo bike which has the rekluse........
Josh will be riding the demo bike but it would be open for anyone else who wants it.......I'd buy one just to get a jump on you into turn one..... :thumbsup:
McMinnville is a long drive away from me, here in S. Oregon. So if i go i'll be riding my VFR - in hopes of taking turns on the demo bike(s).
Any feedback?
