Help i have a xr 200r with a cracked off mag bolt
i was in a rush trying to get a bike fixed for the weekend and put the mag bolt on with my air gun ..... and it cracked off in the crank .... i know i am a dumb a## how do you get it out ... i was thinkng that i would have to dril out the center and use a easy out .... ? has anyone done this ? its a 92 xr 200r :applause::applause::thumbsup::ride:
thanks Jon
If the end isnt sticking out then drilling it out will probably be your only choice.
Get a left handed drill bit and you wont need an easy out.
As soon as it bites ....it'll back it out.
If it broke off from overtightening, not crossthreaded or bottomed out in the hole it is probably pretty loose. As stated above, try to get a left hand drill. Even resharpen a right hand bit so it cuts backward. The flutes will be wrong for clearing the chips but you won't be going that deep.
