idea??
So i have an idea about my messed up pc exhaust, i thought i would see if you guys think it might work. The mid pipe is shot, so i will just have to replace that, the packing is shot (i tore it up getting it out) so i will just have to replace that, the canister on the other hand has a great big dent with a very small hole in the bottom of it, i thought if i could patch that little pea sized hole, and find some way to cap off both ends of the canister then that freeze trick might work, but im not sure, anyone have any ideas?
If the actual canister is bent it might take more than freezing it. The metal is fairly thick there. If it does work you will probably have to do it quite a few times for it to gradually push the dent out. You might be better off with a torch and compressed air for something that thick.
