I need a rear disk, and header 05
The rear disk is warped or something, it has a high pitched chirp when i rotate it.
The stock header is dented, and should probably be replaced. ( I suppose it is robbong me of HP.
I am in San Diego
Thanks guys, and gals.
Mine is making a noise now too, but only when I roll it backwards. Weird. :thumbsup:
ben
ben
My Honda would squeel pretty good when I rolled it backward and I found out that the pads were worn enough to let the metal pad backing plate thingamabob rub on the rotor. But it only did it when I pushed it backward. :ride:
I have new pads on it (EBC), and now that you mention it, it is worse when I roll it backwards.
