why did my rear sag get stiffer 06 yz 450
Weird. Set sag after break-in at 98mm. Last night we set again...same people/method and it was 88mm. Does the titanium spring actually get stiffer over time?
If you set the sag just after you have been riding the wire would have expanded allowing more flex. Obviously the opposite is true if you are setting it at night.
Did you do anything to move the axle between measurements (new sprocket, adjust chain)? That'll change your sag.
